JP_01_137354's avatar
JP_01_137354
Nov 08, 2013
GTM2200 does not answer to equest using udp prot 32774
Hi, We have been replacing old GTM6400 v9 software with GTM200 v11. With V9, GTM was correclty answering peer request using src UDP port 32774. with GTM2200 GTM does not answer the same way to peer requests. BIND is answering instead. Has anyone experienced such behavior with SRC UDP port 32774 ? Thanks.? JP
