Geneve tunneling for AWS GWLB
Renato
Altostratus
Altostratus
Hi!
We are trying to set up a Geneve tunnel between AWS GWLB and BIG-IP VE AdvWAF, but the BIG-IP is returning reset with cause "RST from BIG-IP internal Linux host".
Has anyone ever used this before?
Thanks!
Renato A. Ferreira
3 REPLIES 3
Hello Renato.
This message is displayed when:
"The BIG-IP system receives a RST acknowledgement (ACK) in response to terminating a service check."
REF - https://support.f5.com/csp/article/K13223
Have you checked that your self-ip is allowing that communication?
REF - https://support.f5.com/csp/article/K17333
I recommend you to follow this guidelines:
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-tmos-tunnels-ipsec-13-0-0/1.html
Regards,
Dario.
Regards,
Dario.
I ran into this issue as well. I was running multi nic with this configuration:
sys db provision.1nic value forced_enable
set this to disabled.
setdb provision.1nic disable
This is a BUG.
Br
Andréas
forsan
Altostratus
Altostratus
Hi Renato,
did you manage to integrate F5 and AWS GWLB?
Br
Andréas
