30-May-2003 10:31
31-May-2003 10:31
We'll try to put the other SDK versions so that people can download the appropriate versions for their products.
31-May-2003 10:31
Anyway, obviously this is very painful, since I have no way to find out but to try and fail
on a 4.2 box, which is extremely time consuming...
31-May-2003 10:31
What are you specifically looking for ? A given SDK documentation (SDK 4.2 in your case) is applicable for a specific release of BIG-IP. Therefore, all interfaces/methods described in the SDK documentation should be available for that release.
I don't quite understand what you mean by "to try and fail on a 4.2 box" ? Please advise.
31-May-2003 10:31
OK, once I can get my hands on that, I'll grab it.
31-May-2003 10:31
iControl 4.5. How do I obtain 4.2? Now I understand why I sound so confused...
31-May-2003 10:31
Where is the list you're refering to? I'm looking through the top level html files
with the navigation applet on the left...
31-May-2003 10:31
Specifically, Monitor2 is a redesigned interface that allows you to more efficiently work with monitor templates, associations, and instances. Functionally, Monitor2 exposes the methods the same way that you would work with monitors via Bigpipe or the GUI, so that all 3 interfaces will be more consistent.
31-May-2003 10:31
You're in the right place. In the navigation applet on the left, click on Release Documentation->Release Notes. It should list out what interfaces are new or have been enhanced. I just looked, and it doesn't list out the new methods like I've said though.
