22-Jan-2020 01:52
on my F5 Guest with APM-LTM modules, when i try to open an APM object, all Guest GUI freeze for 30-40 seconds. After that all seems fine.
If i check the Statistics via gui it spike to 90% of CPU, with the ssh top it spike around 70%.
Any suggestion?
PS: The Policy configured are too long (around 150 object), but they are quite easy (LDAP query/auth, ResAssign).
Albe
Solved! Go to Solution.
22-Jan-2020 10:38
Hello Alb3.
F5 GUI normally freezes when CPU usage is too high. This is common when you have to deal with a very heavy configuration with lot of objects.
One possible idea is to increase management plane resources.
REF - https://support.f5.com/csp/article/K26427018
Let me know if this helps.
KR,
Dario.
22-Jan-2020 10:38
Hello Alb3.
KR,
Dario.
