Technical Forum
FQDN Node with Route Domains
Emad
How can we add route domain in FQDN based nodes. In Address based node it can be added with %1 but how this will be done in FQDN based nodes.
5 REPLIES 5
awilhelm
F5 Employee
F5 Employee
Currently this is not supported with FQDN nodes, though it might happen if FQDN nodes are created in an administrative partition with a nonzero route domain (I have not tested this).
There is an RFE open for this, tracked as
ID522465
. This will be implemented in a future release. If you'd like to indicate interest, which helps us prioritize RFEs, please open an SR with F5 Support referencing this ID and asking to be linked to it.
Con_Spathas_246
Here's my attempt at it...
 Rule Name:        MY_RD_FQDN_IRULE
 Rule Date:        01/07/2016
 Rule Version:     1.0
 Rule Description: This iRule is designed to lookup an IP for an FQDN and then use the IP for the serverside connection.
                   Simply edit the RULE_INIT variables to modify for your needs.
                   Test before using in any environment. This rule is provided *as-is* without warranty or liability.
 Rule History:     1.0 - 01/07/2016 - C.Spathas (Ardenta) - Initial Version inspired by DevCentral
                   https://devcentral.f5.com/questions/dynamic-pool-members-with-dns-resolution
when RULE_INIT {
     Set some static variables and lists
    set static::MY_RD_FQDN_GBLVAR "www.google.com"
    set static::MY_RD_FQDN_ROUTE_DOMAIN_GBLVAR "%1"
    set static::MY_RD_FQDN_DNS_SRV_GBLST {8.8.8.8 8.8.4.4}
     Set debug logging on/off (0 for none, 1 for drop/deny/error and 2 for all logging)
    set static::MY_RD_FQDN_DEBUG_GBLVAR 2
when CLIENT_ACCEPTED {
     Select a DNS server from the list and sppend the Route Domain
    set DNS_SERVER_LCLVAR "[lindex $static::MY_RD_FQDN_DNS_SRV_GBLST [expr {int(rand()*[llength $static::MY_RD_FQDN_DNS_SRV_GBLST])}]]$static::MY_RD_FQDN_ROUTE_DOMAIN_GBLVAR"
     Debug Logging
    if {$static::MY_RD_FQDN_DEBUG_GBLVAR==2}{log local0. "DNS Server selected was $DNS_SERVER_LCLVAR"}
     Perform the Lookup and append the Route Domain
    set FQDN_IP_LCLVAR "[lindex [RESOLV::lookup @$DNS_SERVER_LCLVAR -a $static::MY_RD_FQDN_GBLVAR] 0]$static::MY_RD_FQDN_ROUTE_DOMAIN_GBLVAR"
     Debug Logging
    if {$static::MY_RD_FQDN_DEBUG_GBLVAR==2}{log local0. "The resolved IP for FQDN $static::MY_RD_FQDN_GBLVAR is $FQDN_IP_LCLVAR"}
     Perform some rudimentary error checking
    if { $FQDN_IP_LCLVAR ne "" } {
         Use the FQDN IP as the node if there is one
        node $FQDN_IP_LCLVAR
         Debug Logging
        if {$static::MY_RD_FQDN_DEBUG_GBLVAR==2}{log local0. "The connection for [IP::client_addr]:[TCP::client_port] was sent to $FQDN_IP_LCLVAR"}
         If there is no FQDN IP then drop the connection
        drop
         Debug Logging
        if {$static::MY_RD_FQDN_DEBUG_GBLVAR>0}{log local0. "No IP was resolved."}
Lee_Sutcliffe
Nacreous
Nacreous
Having had to deal with this recently, I've added a Code Snippet that addresses this issue but also adds redundancy to the DNS queries, validation of answers and caching.
https://community.f5.com/t5/codeshare/dynamic-fqdn-node-dns-resolution-based-on-uri-with-route-domai...
Dan_Pacheco
Cirrus
Cirrus
On v14.1.2 I tested creating an fqdn node in an administrative partition with a nonzero route domain and it gets created in Common aka route domain.
wlopez
Cirrocumulus
Cirrocumulus
It's still not officially supported.
https://support.f5.com/csp/article/K29925900
I made a post earlier this year about the same subject but never found a solution.
Only received a request for enhancement number:
522465 RFE: Route domain support for FQDN nodes
https://devcentral.f5.com/s/question/0D71T0000069veZ/irule-for-combination-of-fqdn-pool-member-and-r...
https://devcentral.f5.com/s/question/0D51T00007HPxq7SAD/ltm-fqdn-based-node-addition-with-route-doma...
