  • Hi all,
    I faced the following error, when I tried to deploy the form based authentication from this link:
    err tmm[14071]: 01220001:3: TCL error: /Common/Form_based_authentication  - can't read "::loginForm_class": no such variable     while executing "lindex $::loginForm_class 0"
    Data-Group Configuration:
    (tmos) list sys file data-group loginForm_class
    sys file data-group loginForm_class {
        checksum SHA1:1379:69a356ed3b468884c8d7baf94cdd11edc5d473dd
        create-time 2015-06-17:14:57:07
        created-by root
        last-update-time 2015-06-17:14:57:07
        mode 33152
        revision 1
        size 1379
        source-path file:/var/class/loginForm.class
        type string
        updated-by root
    (tmos) list ltm data-group external
    ltm data-group external loginForm_class {
        external-file-name loginForm_class
        type string
    Form-based authentication iRule NOTE: The loginForm.class is just a base64 encoded HTML page which is then wrapped in "quotes". A sample is included at the bottom of this page.
    when RULE_INIT {
      set ::aeskey [AES::key 128]
    when CLIENT_ACCEPTED {
      set forceauth 1
      set auth_status 2
      set ckname BIGIP_AUTH
      set ckpass myPassword
      set asid [AUTH::start pam default_ldap]
      if {  [HTTP::path] starts_with "/user_login"  } {
         Private URI, Auth Required
        if { [HTTP::cookie exists $ckname] } {
          set cookie_payload [HTTP::cookie value $ckname]
          set decryptedCookie [AES::decrypt $::aeskey [b64decode $cookie_payload ]]
          if { not ( $decryptedCookie equals "" ) } {
            log local0. "Decrypted Cookie=$decryptedCookie"
             retrieve the auth status from the session table
            set auth_status [session lookup uie $decryptedCookie]
           If the auth status is 0 then the user is authenticated
          if { $auth_status eq 0 } {
            Cookie Decrypted & Session Auth valid
            set forceauth 0
        if {$forceauth eq 1} {
          set orig_uri [b64encode [HTTP::uri]]
          HTTP::redirect "/Login_form?req=$orig_uri"
         If the user is re-directed to the login form then serve the login form from the BigIP
        if { [HTTP::path] starts_with "/Login_form" && [HTTP::method] equals "GET" } {
           Retrieve the login form from a base64 encoded external class file
          set login_form [b64decode [lindex $::loginForm_class 0]]
          HTTP::respond 200 content $login_form "Content-Type" "text/html"
        } elseif { [HTTP::path] starts_with "/Login_form" && [HTTP::method] equals "POST" } {
           Process the login form and auth the user
           Decode the original URI from the req parameter so we can re-direct to the original
           URI on sucessful auth
          set orig_uri [ b64decode [URI::query [HTTP::request] "req" ] ]
          HTTP::collect [HTTP::header Content-Length]
    when HTTP_REQUEST_DATA {
      set namevals [split [HTTP::payload] "&"]
       Break out the POST data for username and password values
      for {set i 0} {$i < [llength $namevals]} {incr i} {
        set params [split [lindex $namevals $i] "="]
        if { [lindex $params 0] equals "username" } {
          set auth_username [lindex $params 1]
        if { [lindex $params 0] equals "password" } {
          set auth_password [lindex $params 1]
      AUTH::username_credential $asid $auth_username
      AUTH::password_credential $asid $auth_password
      AUTH::authenticate $asid
      HTTP::collect
    when AUTH_SUCCESS {
      if {$asid eq [AUTH::last_event_session_id]} {
         Now the user has authenticated lets give them an encrypted cookie with their authID
         We'll also add the AUTH::status to a session entry with the authID as the key
         We can then re-direct the user to the page they originally asked for
        set authStatus [AUTH::status $asid]
        session add uie $asid $authStatus 1800
        set encrypted_asid [b64encode [AES::encrypt $::aeskey $asid]]
        set authcookie [format "%s=%s; path=/; " $ckname $encrypted_asid ]
        HTTP::respond 302 Location $orig_uri "Set-Cookie" $authcookie
    when AUTH_FAILURE {
               HTTP::respond 200 content "Authentication Failed"
    when AUTH_WANTCREDENTIAL {
               HTTP::respond 200 content "Authentication Credentials not provided"
    when AUTH_ERROR {
      HTTP::respond 200 content "Authentication Error"
    and applied the iRule at the ldap authentication profile.:loginForm_class and of course added the "loginForm" in the path /var/class/loginForm.class
