LarsKristensson's avatar
LarsKristensson
8 months ago
Caching based on Surrogate-Control header
I want to configure a virtual server to use Web Acceleration caching based on the Surrogate-Control response header instead of the Cache-Control response header.
Both headers must be preserved, so I can't just overwrite the Cache-Control header with the Surrogate-Control header upon HTTP_RESPONSE.
Is there some built in support for this, or is there some nice solution to this?
  • Hello LarsKristensson​
    Not sure if this is possible.
    But you could save original Cache-Control response header in HTTP_RESPONSE in a variable, replace it with Surrogate-Control header so it can be used by Web Acceleration caching and then in HTTP_RESPONSE_RELEASE event restore the original value of Cache-Control from variable.
    You could check something like this
    when HTTP_RESPONSE {
    	# Check if Surrogate-Control header exists in the response
        if { [HTTP::header exists "Surrogate-Control"] } {
    		set surrogate_control [HTTP::header value "Surrogate-Control"]
    		# Check if Cache-Control header exists in the response
    		if { [HTTP::header exists "Cache-Control"] } {
    			# Save the original Cache-Control header value in a variable
    			set original_cache_control [HTTP::header value "Cache-Control"]
    		# Replace Cache-Control with Surrogate-Control for Web Acceleration
    		HTTP::header replace "Cache-Control" $surrogate_control
    when HTTP_RESPONSE_RELEASE {
        # Check if we saved a Cache-Control value
        if { [info exists original_cache_control] } {
            # Restore the original Cache-Control header
            HTTP::header replace "Cache-Control" $original_cache_control
    • LarsKristensson's avatar
      LarsKristensson
      Yes, after posting my question I figured out that I could replace the Cache-Control header in HTTP_RESPONSE. However, storing it in a variable is not enough since the response may be served from the cache at a later point.
      I ended up with this:
          HTTP::header insert Saved-Cache-Control [HTTP::header Cache-Control]
          HTTP::header replace Cache-Control [HTTP::header Surrogate-Control]
          if { [HTTP::header exists Saved-Cache-Control] } {
              HTTP::header replace Cache-Control [HTTP::header Saved-Cache-Control]
              HTTP::header remove Saved-Cache-Control
