09-Jan-2022 13:19
Hi everyone,
we are new to this LTM/ASM product. we are still evaluating features but after using a deprecated IIS iApp we stuck on loading security general settings bug which mentioned as Bug ID 1039245. how ever there is no direct fix for this and document asks about contacting support!
there are two concerns:
1- seems we cannot contact support without having a Serial Number. however our test platform is VE.
2- why isn't there an exact fix to the solution and we need to contact support! (our colleague asked it because we are evaluating not only product features but also support methods).
Thanks in advance
Joe
Solved! Go to Solution.
17-Jan-2022 08:20
Hello Joe, support is available to VE's as well.
Regarding the fix, as stated in K73215042 you will need support engineers to provide you with an engineering hotfix. This means the problem is in BIG-IP software, and can't be fixed by an user/administrator.
Future software versions, still unreleased to this date, will likely fix the issue -- but for now this is the only way to address it.
Hope this helps
CA
17-Jan-2022 08:20
Hope this helps
CA
17-Jan-2022 13:44
Dear CA,
That was the exact information I needed to move forward. thanks a lot.
however i check BIG-IP VE 16.1.2.1 and found fix to the bug ID I listed above is included in it.
thanks
Joe
