awan_m's avatar
awan_m
Aug 02, 2023
Solved
FIX Message Response
Hi - i am trying to do a FIX message validation on F5 - and in case of invalid client IP - i want to send a FIX response back .
currectly if the IP address of a FIX login Message does not match the client ID associated in a Datagroup - the F5 rejects the connection and does TCP::close
can i respond with a Reject FIX message ?
  • awan_m's avatar
    awan_m
    Aug 03, 2023
    i tried to understand it but i cannot -
    BIGPROTO::enable_fix_reset true -- what would this do
    BIGPROTO::enable_fix_reset false -- what would this do
  • awan_m In the section where you do the TCP::close replace it with the following and then the HTML with the information you want to display to the end user.
            HTTP::respond 200 content {
    <html>
    <head>
    <title>Page Not Found</title>
    </head>
    <body>Page Not Found</body>
    </html>
    • awan_m's avatar
      awan_m
