21-Sep-2023 02:05
Dears
We will migrate Firewall behind APM to different vendor, Is this will impact anything on APM device? or we will need to change something in APM.
What's the recommended action from APM administrator through this firewall migration to avoid any interruption?
Solved! Go to Solution.
21-Sep-2023 08:03
Migrating a firewall behind an F5 APM to a different vendor could indeed impact F5 APM device, depending on the specific setup and configuration of your network. It is important to check the compatibility between F5 APM and the new firewall and adjust the configurations accordingly.
First, ensure that the new firewall is compatible with your F5 APM. You can check this information in the vendor's documentation or by contacting their support
21-Sep-2023 08:03
