06-Jan-2022 07:22
Hi Team ,
What happens to preferred order if I force failover the traffic-group ?If execute below command after the failover will the preferred order changes ?
run /sys failover standby traffic-group traffic-group-1
11-Jan-2022 12:45
The preferred order will not change but rather the next active device will. In your example, bigip-test-1 will become active and bigip-test-2 will be the next active device. Also note, that you have auto failback enabled. The traffic-group-2 will automatically failover back to bigip-test-2 after 60 seconds of being available.
12-Jan-2022 00:35
So you mean IF I run the failover command on bigip-test-2 ....bigip-test-1 will become active but after 60sec it will again failover to bigip-test-2 as auto failback is configured ?
12-Jan-2022 05:13
That is correct.
8. If you configured the Failover Methods setting with a value of Failover using Preferred Device List and then Load Aware, then configure the following settings. Otherwise, skip this step.
https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/bigip-system-device-service-clustering-administration-13-1-0/6.html
