Technical Forum
Custom Alert Banner
F5FltDrv.sys driver is triggering of the operating system fault
Burak_Sahan
When ı run BIG-IP Edge Client or Edge Client browser, F5FltDrv.sys driver is triggering of the operating system fault for Windows OS. I found some logs related with TDI like "This filter has not been certified by Microsoft and may cause system instability." Is there any fixed F5 version for this or can we solve this problem with any other solution?
4 REPLIES 4
Hi @Burak_Sahan ,
May this Articles help you , I’m not aware with your issue , but just to give a clue :
https://www.solvusoft.com/en/files/bsod-blue-screen-error/sys/windows/f5-networks-inc/big-ip-edge-cl...
https://support.f5.com/csp/article/K16666
_______________________
Regards
Mohamed Kansoh
Hi @Mohamed_Ahmed_Kansoh ,
Thank you, but these articles are not solving this issue.
Okay @Burak_Sahan ,
try to Cancel the " Accepted solution " of last reply and we can wait for an expert  more than me to reply.
I just wanted to help or give some ideas may lead to solid solution for your issue.
anyway , I like to search about your issue and share with you some results.
Check the below Articles and inform me :
>> https://www.pconlife.com/viewfileinfo/f5fltdrv-sys/
>> https://cdn.f5.com/product/bugtracker/ID760395.html
I hope it helps you
Regards
Mohamed Kansoh
Leslie_Hubertus
Community Manager
Community Manager
Hi @Burak_Sahan - did you check out @Mohamed_Ahmed_Kansoh's reply? Did the other two article he shared help you, or are you still having the issue?
