Technical Forum
f5 token based authentication using uri module throw error
reddev12
Altocumulus
Altocumulus
using below yml file with header as below and token is variable authx . error i am getting is "authx is undefined"
is the header correct ?
- name: "{{ name }}"
uri:
url: "{{ url }}"
method: "GET"
headers:
X-F5-Auth-Token: "{{ authx }}"
validate_certs: "no"
status_code: "{{ status|default(200) }}"
timeout: 60
ignore_errors: True
delegate_to: localhost
@JRahm
3 REPLIES 3
JRahm
Community Manager
Community Manager
what tool is this yaml for and how is it being used?
remotely we will execute the ansible script ...and token is created from other script and kept as ansible vars ...just want to place that token variable in this yaml
url will contain f5 rest api
JRahm
Community Manager
Community Manager
authx variable isn't populating, so that will need to be solved before you can troubleshoot anything else. what does that playbook look like?
