Technical Forum
F5-SDK Error When Attempting to Add Pool Members
Ken_R_
I've just started programming with Python (3.6.8) and found the f5-sdk module to be interesting. I've written a script to build nodes, pool members and a virtual server (v13.1.1.4), however while adding pool members to a pool, I receive the following error:
'Traceback (most recent call last):
 File "f5_build_sdk.py", line 68, in ltm_build
  name=pool[tuple('member')] + ':' + pool[tuple('port')],
TypeError: 'Pool' object is not subscriptable'
The REST api documentation suggests the object it is looking for is an array type, which I believe I have configured as such. I've done some other checking with various resources, but can't seem to find an answer. Below is the code I've written. Any help would be much appreciated.
#!/usr/bin/python
# -*- coding: utf-8 -*-
import requests
from ansible.module_utils.network.f5 import icontrol
from f5.bigip import ManagementRoot
from getpass import getpass
from icontrol.exceptions import iControlUnexpectedHTTPError
import sys
change = input('Change or Rollback? ').lower()
password = getpass()
requests.packages.urllib3.disable_warnings()
mgmt = ManagementRoot('test-ltm', 'admin', password)
ltm = mgmt.tm.ltm
# Build Details
node_details = [{'name': 'node-1', 'address': '1.1.1.2'}]
pool_details = [{
  'name': 'pool-1',
  'member': [{'name': 'node-1', 'port': '80'}],
  'monitor': 'tcp',
  'description': 'Test SDK Pool',
  'method': 'round-robin'
virtual_details = [{
  'name': 'virtual-1',
  'vip': '1.1.1.1:80',
  'pool': 'pool-1',
  'type': 'standard',
  'profiles': [{
    'name': 'f5-tcp-wan',
    'context': 'clientside'
    'name': 'f5-tcp-lan',
    'context': 'serverside'
    'name': 'HTTP-X-Forwarded'
def ltm_build():
  if change == 'change':
    # Node Creation
    for node in node_details:
      try:
        ltm.nodes.node.create(
          partition='Common',
          name=node['name'],
          address=node['address'])
      except iControlUnexpectedHTTPError as error:
        print('\n', f'node: {node["name"]} already exists...')
        sys.exit()
    # Pool Creation
    for pool in pool_details:
      try:
        ltm.pools.pool.create(partition='Common', name=pool['name'])
        pool = ltm.pools.pool.load(name=pool['name'])
        pool.members_s.members.create(
          partition='Common',
          name=pool['member'] + ':' + pool['port'],
          monitor=pool['monitor'])
      except (iControlUnexpectedHTTPError, TypeError) as error:
        print('\n', f'pool: {pool["name"]} server already exists...', '\n')
        sys.exit()
    # Virtual Server Creation
    for virtual in virtual_details:
      try:
        ltm.virtuals.virtual.create(
          partition='Common',
          name=virtual['name'],
          destination=virtual['vip'],
          mask='255.255.255.255',
          ipProtocol='tcp',
          pool=virtual['pool'],
          profiles=virtual['profiles'],
        print(f'virtual_server: {virtual["name"]} server already exists...', '\n')
        sys.exit()
  elif change == 'rollback':
    # Remove Virtual Server
      virtual = ltm.virtuals.virtual.load(
        partition='Common', name=virtual['name'])
      virtual.delete()
    # Delete Pool
      pool.delete()
    # Delete Node
      ltm.nodes.node.load(partition='Common', name=node['name']).delete()
      print('\n', 'Rollback Complete...', '\n')
if __name__ == '__main__':
  ltm_build()
2 REPLIES 2
Hi Ken R.
In your code; node, pool and virtual server definitions are dictionary in the list. You can remove list. "[ ]"
or...
	partition='Common',
	name=pool[0]['member'][0]['name'] + ':' + pool[0]['member'][0]['port'],
	monitor=pool[0]['monitor'])
...can you try above code instead of following?
	partition='Common',
Ken_R_
eaa,
Thanks for you help. I was able to write the script a little differently and its working the way I was hoping. Below is the script if you're curious...thanks again.
#!/usr/bin/python
import requests
import sys
# Determines the type of change to be made.
mgmt = ManagementRoot('us6645ny-nelab-ltm2', 'admin', password)
ltm = mgmt.tm.ltm
# Node Details
nodes = [{'name': 'sdk-node', 'address': '12.7.20.19'},
     {'name': 'sdk-node2', 'address': '12.7.20.192'}]
# Pool Details
pool_name = 'sdk-pool'
member_port = '80'
# Virtual Server Details
vs_name = 'sdk-virtual'
vip = '192.168.100.10'
port = '80'
profiles = [{'name': 'f5-tcp-wan', 'context': 'clientside'},
      {'name': 'f5-tcp-lan', 'context': 'serverside'},
      {'name': 'serverssl', 'context': 'serverside'},
      {'name': 'http'}]
def ltm_build():
    try:
      ltm.pools.pool.create(name=pool_name, monitor='tcp')
      pool = ltm.pools.pool.load(name=pool_name)
      for node in nodes:
        ltm.nodes.node.create(partition='Common',
            name=node['name'], address=node['address'])
        pool.members_s.members.create(partition='Common',
            name=node['name'] + ':' + member_port)
      params = {
        'name': vs_name,
        'destination': '{}:{}'.format(vip, port),
        'mask': '255.255.255.255',
        'pool': pool_name,
        'profiles': profiles,
        'partition': 'Common',
        'sourceAddressTranslation': {'type': 'automap'},
      ltm.virtuals.virtual.create(**params)
    except iControlUnexpectedHTTPError:
      print('Duplicate Objects Exist...Build Failed')
      sys.exit()
  ltm_build()
