14-Apr-2022 09:59
Guys, is there a way to stright connect to a RDP connection in a portal rather than having the browser to download it and then connect.
Thanks,
Solved! Go to Solution.
14-Apr-2022 17:21
14-Apr-2022 17:21
Is this what you're asking?
15-Apr-2022 08:44
Thanks Peter, that helped as I am provisioning a F5 proxy RDP.
Hi Leopoldo, there is an option in Chrome when the file is download to set as open always these kind of files. That way RDP connections will not be downloaded, but opened.
Regards.
