19-May-2022 04:09
Hi Experts,
i have builded F5 partner lab in Vmware workstation pro 15.
i have followed all the steps in that setup guide but still pool members showing down. while taking tcpdump getting below error.
bigipA:Active:Standalone] config # tcpdump -ni 0.0 host 10.1.20.12
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
03:42:04.870202 ARP, Request who-has 10.1.20.12 tell 10.1.20.241, length 35 out slot1/tmm0 lis=
03:42:05.870443 ARP, Request who-has 10.1.20.12 tell 10.1.20.241, length 35 out slot1/tmm0 lis=
03:42:06.870237 ARP, Request who-has 10.1.20.12 tell 10.1.20.241, length 35 out slot1/tmm0 lis=
03:42:07.870234 ARP, Request who-has 10.1.20.12 tell 10.1.20.241, length 35 out slot1/tmm0 lis=
03:42:08.870455 ARP, Request who-has 10.1.20.12 tell 10.1.20.241, length 35 out slot1/tmm0 lis=
03:42:09.870439 ARP, Request who-has 10.1.20.12 tell 10.1.20.241, length 35 out slot1/tmm0 lis=
pool memeber: 10.1.20.12 self IP: 10.1.20.241 ( untagged 1.2 internal vlan- non-floting)
Doc-followed: vLab Setup Guide for VMware Workstation (Document version 13.0.A)
Thanks,
RK
19-May-2022 04:16
So does VMnet4 have a gateway set?
can your lamp server, see (ping) the gateway?
can your big-ip, see (ping) the gateway?
From one thing, its been a couple of years since i used workstation, but not sure what "custom" does.
I would have said you wanted a Host-only network, or least test it with that first.
My first guess is that this is a workstation / network interface issue.
So also check your mac addresses under Network > Interfaces and make sure they align to your workstation config of the interfaces you have assigned.
19-May-2022 05:26
i have just follwed the stpes in that partner guide.
i have tried host only option too but same error.
Vmnet4 doesn't configure any gateway. even i couldnt ping f5 self IP from the lamp server.
do you succest me to check my PC interfaces?? is it something related to Network interface issue?
Thanks,
RK
19-May-2022 08:47
Did you configure the interfaces in the Lamp? a simple test is make a ping from the lamp to the selfip configured in the same network in the bigip, if this doesn´t work probably your issue in the lamp network interface configuration, additional review that the F5 are in the same vnet than the lamp.
20-May-2022 05:21
Have you got 2 lamp servers on that network as per the diagram?
Can those 2 LAMP servers see each other?
19-May-2022 08:50
20-May-2022 00:40
Could you try to assign in the interface of the LAMP and F5 a generic network as in the next example:
For Lamp:
For the F5 in my case the network connected to Lamp is Adapter 3:
Hope it´s works.
24-May-2022 21:37
Hi Sebastian,
i have tried different interfaces also but same issue.
-RK
25-May-2022 06:16
Could you try to use Vmware player? is really wired it doesn't work, it could be a wrong configuration in your vmware workstation
