Technical Forum
Custom Alert Banner
F5 packet buffer
Michaelyang
Hello,
Is there any setting that allows the proxy to do packet buffer
Wait for the proxy to accumulate a certain amount of packets before sending them to the destination
Because it is a cross-sea connection, it will take more time if small packets keep passing back and forth.
F5 itself has the ability to do packet cutting/combining, not through the network equipment (router/switch) to do?
Any help is appreciate.
1 ACCEPTED SOLUTION
2 REPLIES 2
Mike757
MVP
MVP
Hi, @Michaelyang
Sounds like you're describing Nagle's algorithm.
If you wish to see documentation about it, maybe start with K50411377, but if you google "nagle f5" you'll get plenty of hits.
Note that it works only with TCP. Not sure it applies to your case.
/Mike
JRahm
Community Manager
Community Manager
