17-May-2021 05:07
Hi experts,
Just wanted to ask. usually I used show sys connection cs-server-addr or cs-client-addr to see if client is able to reach its destination server.
show sys connection output:
client\source ip > VIP > snat IP > pool member
what happened is I get this result.
client\source ip > VIP > snat IP > VIP
2nd and 4th are the same IP address, does any encountered the same situation?
What could be causing this issue?
TIA
Solved! Go to Solution.
18-May-2021 11:33
Hello f5mkuDefault.
What type of VS is the one you are pointing above (https://support.f5.com/csp/article/K55185917)?
Could you check if you have 'translate-address' option disabled in your VS configuration?
Regards,
Dario.
17-May-2021 11:53
Hello f5mkuDefault.
There is no an issue.
This traffic represents pool members probes, for monitoring their status.
Regards,
Dario.
17-May-2021 18:48
I have been using ltm for quite some time...usually when you do show sys connection the last IP address is the pool member...
However for this case the last IP address indicated is the vip address..
Show sys output indicateds like this:
client 》vip 》snat ip 》vip
Instead of showing it this way:
client 》vip 》snat ip 》pool member
I dont think it is normal so I wanted to know what could trigger this situation.
18-May-2021 11:33
Hello f5mkuDefault.
Regards,
Dario.
01-Jun-2021 22:02
hi Dario,
Enabling the translate address and port fix the problem. But this is strange as we do not touch the advance settings. So not sure how it became disabled.
Thanks,
11-Jun-2021 11:27
Hello f5mkuDefault.
Great to hear that the issue got solved.
Please, don't forget to mark my answer as "the best" to help other people to find this solution.
Regards,
Dario.
