Technical Forum
F5 LTM LB
starboy
Cirrus
Cirrus
Hi All
I have three tier architecture Web--> App---> DB. Web talks to App talks to DB and I want to implement F5 Load Balancer. each server has redundant is that possible to load balance traffic for each tier servers. Like when the client requests the web it will distribute to the web servers and when the web server talks to the app same load balancing will be done and so on... is that possible to do in a one F5 LTM box?
2 ACCEPTED SOLUTIONS
CA_Valli
MVP
MVP
Sure thing, you just need to configure a set of Virtual Server - each one will serve requests to one of those components and can be configured to load balance the traffic to a set of real servers in you farm.
If those components (web, app, db) are served by the same set of reals and you need requests to persists across the components, it's also possible to (optionally) implement additional configuration that will guarantee that the same server will respond to all.
 Regards
CA
Of course, you can make it by configuring multiple VIPs, each one for your service (web, app, DB) and assign pool members for each VIP which represent your service.
But make sure that each sercice when want to connect to another service will use VIP IP not real IP of server.
2 REPLIES 2
CA_Valli
MVP
MVP
 Regards
CA
