ybloi's avatar
ybloi
Apr 14, 2019
F5 load balancer 3400 get stuck in loading state
Hi guys, anyone facing load balancer get stuck in loading state before? I try to reboot and console into the device but unfortunately no works.The error code is 06b. Thank you.
  • Hi,
    you have 2 alternatives:
    • First one (more simple):
    Connect in Serial and during the boot try to change the boot volume (don't use default). of course if you have several volumes
    • Second one: create a bootable key --> Normally F5 provides you one with the equipment:
    https://support.f5.com/csp/article/K13164
    You can create this bootable key on the second equipment (simple and quick). then re-install you equipment.
    If you need assistance don't hesitate.
    Regards
