Josh_41258
May 06, 2010Nimbostratus
F5.IsHandler.dll help
Is anyone using the F5.IsHandler.dll module on IIS7/7.5 boxes to use the WMI monitor? We are unable to get this working in Windows 2008 R2 using IIS 7.5..
Would love some pointers.
I've tested this on Win2k8 with IIS7 but I don't have Win2k8R2 with IIS7.5 to test this on. Are you using the ISAPI filter or the new native HTTP Module? I do know that IIS is going away from the ISAPI model so if you haven't tried it, I'd recommend taking the HTTP Module for a spin. The functionality is the same, just the interface to IIS is different. Details are on my blog at:
http://devcentral.f5.com/weblogs/Joe/archive/2009/12/23/x-forwarded-for-http-module-for-iis7-source-included.aspx
-Joe
I am in the same boat. any updates ?
the 7.5 steps from here fail: https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm-concepts-11-4-0/21.html
i get this: HTTP Error 404.4 - Not Found The resource you are looking for does not have a handler associated with it.
I see that this is an old thread.
Were you able to resolve the issue?
I am experiencing the same 404.4 issue with the F5 RealServer on IIS 7.5
