AbdullahAlshehri's avatar
AbdullahAlshehri
Apr 26, 2022
Solved
F5 iRule Geolocation restriction
Hello,
I want to know how I can restrict the access to specific one country only via iRule.
For example: allow only users to access from "US" and block all other countries.
  • when FLOW_INIT {
        # Drop everything except US
        if { ! ([whereis [IP::client_addr] country] equals "US") } {
            log -noname local0. "Dropping connection from [IP::client_addr]/[whereis [IP::client_addr] state country continent ]"
            drop
    AFM not required.
  • I would make sure the LTM is updated with the latest GeoLocationUpdates from F5. Otherwise you will likely block valid US addresses.
    Here is one very simple way to do this:
    # Block_non_US_IP
    # iRule to drop traffic that is not from US addresses
    when CLIENT_ACCEPTED {
    if { not [whereis [IP::client_addr] continent country] == "NA US" } {
    log local0. "Connection from [IP::client_addr] [whereis [IP::client_addr] continent country] to [virtual name] [IP::local_addr] : Blocked."
    drop
    • AbdullahAlshehri's avatar
      AbdullahAlshehri
      Hello David,
      Thank you for your reply.
      Just to clarify more, I'am using F5 DNS/LTM and I will apply the iRule on the VS.
      Also, I prefer to block the traffic when TCP-SYN or UDP packet come from non-US country. I got iRule from clouddocs.f5 that may will work
      when FLOW_INIT {
      set ipaddr [IP::client_addr]
      set locale [whereis $ipaddr country]
      log local0. "IP Address/Counry $ipaddr/$locale"
      switch $locale {
      "US" { return }
      default { ACL::action drop }
  • when FLOW_INIT {
            drop
    AFM not required.
      AbdullahAlshehri
      Hello  David_Gill,
      I tested the iRule which I mentioned early and it worked fine.
      Is there any difference with the one which you mentioned?
      • David_Gill's avatar
        David_Gill
        Icon for Cirrus rankCirrus
        Functionally they do the same thing however ACL::action drop requires AFM whereas drop on its own does not which means the snippet works for a larger audience. Switch is generally used when making more than one comparison (as shown at https://clouddocs.f5.com/api/irules/ACL__action.html) which is why I used a single if statement. There is no need to define any variables either. That said, in both cases the end result is the same.
