elastic_82555's avatar
elastic_82555
Sep 14, 2012
f5-icontrol-10.2.0.2 gem causing various warnings with ruby 1.9.3
Installed the gem, and get had to do the following workarounds...
ruby /home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/f5-icontrol-10.2.0.2/examples/get-version.rb 192.168.1.1 admin admin
/home/elastic/.rvm/rubies/ruby-1.9.3-p194/lib/ruby/site_ruby/1.9.1/rubygems/custom_require.rb:36:in `require': cannot load such file -- soap/wsdlDriver (LoadError)
from /home/elastic/.rvm/rubies/ruby-1.9.3-p194/lib/ruby/site_ruby/1.9.1/rubygems/custom_require.rb:36:in `require'
from /home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/f5-icontrol-10.2.0.2/lib/f5-icontrol.rb:2:in `'
from /home/elastic/.rvm/rubies/ruby-1.9.3-p194/lib/ruby/site_ruby/1.9.1/rubygems/custom_require.rb:60:in `require'
from /home/elastic/.rvm/rubies/ruby-1.9.3-p194/lib/ruby/site_ruby/1.9.1/rubygems/custom_require.rb:60:in `rescue in require'
from /home/elastic/.rvm/rubies/ruby-1.9.3-p194/lib/ruby/site_ruby/1.9.1/rubygems/custom_require.rb:35:in `require'
from /home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/f5-icontrol-10.2.0.2/examples/get-version.rb:4:in `'
To get round this, I did the following:-
gem install soap4r
Try again:-
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/xsd/charset.rb:13: warning: variable $KCODE is no longer effective
/home/elastic/.rvm/rubies/ruby-1.9.3-p194/lib/ruby/site_ruby/1.9.1/rubygems/custom_require.rb:36:in `require': iconv will be deprecated in the future, use Stringencode instead.
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/xsd/xmlparser.rb:74:in `': XML processor module not found. (RuntimeError)
from /home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/wsdl/parser.rb:12:in `'
from /home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/soap/wsdlDriver.rb:9:in `'
To get round this error, I followed the code here:- http://railsforum.com/viewtopic.php?id=41231
Essentially, changed, line 66 in file /home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/xsd/xmlparser.rb
before:
c.downcase == name
After
c.to_s.downcase == name
This solves the above problem, but now I get all sorts of warnings.....
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/soap/property.rb:68: warning: encoding option is ignored - u
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/soap/property.rb:69: warning: encoding option is ignored - u
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/soap/property.rb:70: warning: encoding option is ignored - u
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/soap/rpc/element.rb:226: warning: Hashindex is deprecated; use Hashkey
/home/elastic/.rvm/gems/ruby-1.9.3-p194/gems/soap4r-1.5.8/lib/soap/generator.rb:276: warning: encoding option is ignored - UTF8
BIG-IP_v11.1.0
Hei, it works, but would be nice id someone could update the gem to fix all of the above and release a new version?
thanks
Sc0tt....
  • Hi, I got around this by using soap4r-ruby1.9 instead of soap4r. Ugly, but it seems to work. It would be good if the f5-icontrol gem was updated to use something other than soap4r, for example savon.
    Jeff
  • I ran into the same types of issues with the f5-icontrol (11.1.0.1) gem and ruby 1.9.3 (no issues seen on ruby 1.8.7).
    I installed soap4r-ruby1.9 instead of soap4r, as Jeff did.
    Now the only thing I see is:
  • HI,
    Sorry, been a long time, have now installed the soap4r-ruby1.9, and ruby 1.9.3p194 is working a treat, using f5-icontrol (11.3.0.0)
    thanks to all
    Sc0tt..
    • cpalmer9_17622's avatar
      cpalmer9_17622
      Hit the same issues when I went from Ruby 1.8 -> 2.0. ruby 2.0.0p195 soap4r-ruby1.9 (2.0.5) [uninstall soap4r] Things seem cleaner now.
  • pr's avatar
    pr
    Hi All,
    You people saved my day thanks to all of you guys :)
