jkramer9's avatar
jkramer9
Feb 23, 2020
F5 DNS Wide IP and Express Questions
Hi everyone,
I'm looking for clarification on a couple of things related to the F5 DNS and Listener, and a monitoring question.
  1. Simple question, if I have an FQDN (Wide IP) configured, but disabled, how does the DNS Listener handle such queries? Would the F5 simply move on to DNS Express for an answer in such a situation where the matching Wide IP is disabled on the GTM/DNS?
  2. I'm curious as to how the F5 DNS handles queries which have matching zone records for the primary domain, but not the sub domain. For example, if I have a zone recorded created only for dev.f5.com and a DNS query is sent to the F5 for labs.dev.f5.com, would the F5 find a match and respond from the dev.f5.com zone record?
  3. May I know what the best method is (which doesn't require configuration changes) to monitor and track queries and responses sent to and from the F5. For eg, if I send a DNS query to the F5 for name resolution and load balancing, I would like to know how the F5 DNS handled such a request in detail (how it determined the resolution at the DNS and Load Balancing levels)
Thank you!
  • NAG's avatar
    NAG
    1) Simple question, if I have an FQDN (Wide IP) configured, but disabled, how does the DNS Listener handle such queries? Would the F5 simply move on to DNS Express for an answer in such a situation where the matching Wide IP is disabled on the GTM/DNS?
    ANS: Yes, BigIP will simply move on to DNS Express.
    Refer to to "DNS request order of operation for BIG-IP systems" section of https://support.f5.com/csp/article/K14510
    2) I'm curious as to how the F5 DNS handles queries which have matching zone records for the primary domain, but not the sub domain. For example, if I have a zone recorded created only for dev.f5.com and a DNS query is sent to the F5 for labs.dev.f5.com, would the F5 find a match and respond from the dev.f5.com zone record?
    ANS: Request is handled as per "Unhandled Query Actions" setting.Following article explains quite well.
    K14510: Overview of DNS query processing on BIG-IP systems
    3) May I know what the best method is (which doesn't require configuration changes) to monitor and track queries and responses sent to and from the F5. For eg, if I send a DNS query to the F5 for name resolution and load balancing, I would like to know how the F5 DNS handled such a request in detail (how it determined the resolution at the DNS and Load Balancing levels)
    ANS::
    K25751652: How to configure Decision Logging for the F5 BIG-IP DNS/GTM to local log directory
    https://support.f5.com/csp/article/K25751652
    K65762138: Configuring BIG-IP DNS to log dns queries and responses
    https://support.f5.com/csp/article/K65762138
    Hope this is helpful.
    Regards,
    Nag
  • >Simple question, if I have an FQDN (Wide IP) configured, but disabled, how does the DNS Listener handle such queries? Would the F5 simply move on to DNS Express for an answer in such a situation where the matching Wide IP is disabled on the GTM/DNS?
    This depends on the resolution options set in the DNS profile on the listener - this defines the resolution steps taken by the BigIP to resolve the name. If you have DNS Express enabled in the DNS profile, then yes - that will be the next resolution step.
    Yes - that is basically how DNS glue records work. But responses from dev.f5.com for hosts in labs.dev.f5.com will not be authoritative.
    Remember - this is just descending to bind - so the behaviour is as per bind.
    K14615: Configuring the BIG-IP DNS system to log wide IP request information
