Technical Forum
F5 cluster to OpenShift integration
kouriada
Hello everyone,
I would like to ask, if exist some resources/manual for integration of f5 CLUSTER with Openshift, looking for some hands-on tutorials as well. I found a lot of materials for stand-alone f5, but it isn't exactly what I am looking for and quite struggling with cluster f5 and OpS.
For example: not sure if I have to configure each self-IP or only float in OpS, routing domains, type of vxlan, etc..
I will appreciate any good link for cluster integration that kicks my brain to move on 🙂
Thank y!
1 REPLY 1
F5 BIG-IP Container Ingress Services (CIS) and F5 OpenShift Container Integration videos on LearnF5 .They are free and in their description also other links are mentioned.
