Prakin's avatar
Prakin
Icon for Cirrus rankCirrus
May 30, 2022
F5 CLI preference pager disabled - command
hi guys,
when i execute the command "modify cli preference pager disabled display-threshold 0". It puts F5 into changes pending state, how to avoid it?.  because if i am running an automated back up of some commands executing on the both devices, later it shows "Not in sync". how to overcome this.
Br,
Prakash
      • Hello,
        I think that's why you see "changes pending state" because any change you will make on the F5, you must sync manually. If you need to avoid this message, you can change the syncing mode to automatic instead of manual.
        Thanks,
