21-Nov-2022 22:49
i want to do WAF clean up but what/where i have to check the trash files to be deleted? to increse the performance and save space
Solved! Go to Solution.
22-Nov-2022 01:36
Hi @THE_BLUE ,
Issue these Commands on bash :
#df -h
#df -i
you find like the below output , this from my lab :
> you can see the available space against total memory for each path , so detect the most exhausted path and remove and unwanted files , such as old QKview , UCSs , Images software.iso , and Pcap files that resulted from Tcpdumps.
> open the Following Tabs in your F5 GUI and make sure it doesn’t contain large files :
- UCSs :
-Qkviews :
-Software Images :
> Make sure all of these tabs are free and not contain large files.
_______________________________________________________________________
for more information to maintain your Desk Space
Follow this KB :
https://support.f5.com/csp/article/K14403
22-Nov-2022 01:36
Hi @THE_BLUE ,
#df -h
#df -i
- UCSs :
-Qkviews :
-Software Images :
Follow this KB :
