Technical Forum
F5 Botdefense behind Cloudflare
Emil
Altocumulus
Altocumulus
Hi community,
Does anyone know how to fix botdefense protection profile when we have a setup Client > Cloudflare proxied > F5 AWAF.
It seems that botdefense matches the client browser as malicious bot all the time : Non-browser presenting as FireFox -Edge -Chrome.
GET / HTTP/1.1
Host: XXXXXX
Connection: Keep-Alive
CF-RAY: XXXXXXX
CF-Visitor: {"scheme":"https"}
user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:105.0) Gecko/20100101 Firefox/105.0
accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8
accept-language: en-US,en;q=0.5
dnt: 1
upgrade-insecure-requests: 1
sec-fetch-dest: document
sec-fetch-mode: navigate
sec-fetch-site: none
sec-fetch-user: ?1
pragma: no-cache
cache-control: no-cache
cookie: XXXXXX
Bot Name Non-browser presenting as FireFox
Bot Class Malicious Bot
Bot Categories Browser Masquerading
I do not see the X-Forwarded; CF-Connecting-IP, CF-IPCountry: headers in the blocked request. I guess it is not showing them when connection is blocked.
Regards.
1 ACCEPTED SOLUTION
Emil
Altocumulus
Altocumulus
I found the solution to my problem. In case someone else is having the same issue.
https://support.f5.com/csp/article/K58581034?utm_source=f5support&utm_medium=RSS
3 REPLIES 3
James_Jinwon_Lee
F5 Employee
F5 Employee
Please check whether your configuration is related to the below k article.
https://support.f5.com/csp/article/K07408554
Emil
Altocumulus
Altocumulus
Hi James,
Thanks for the suggestion. It seems a different scenario. We have suspicious with CAPTCHA and malicious are set to block.
Also the API setting is disabled as per the default config for relaxed bot defense profile.
Regards,
Emil
Emil
Altocumulus
Altocumulus
