Technical Forum
F5 BIG-IP Link Controller cannot be auto-discovered virtual servers
BINCONG_LIN
 F5 BIG-IP Link Controller cannot be auto-discovered virtual servers,
LC Bigip Version: BIG-IP 15.1.1 Build 0.0.6
Problem:
A new VS is added to the LTM module of the F5 LC, but the newly added VS cannot be automatically found in the link control module of the same F5 LC.
0691T000009jmzsQAA.jpgThis cw VS was added three days ago,
0691T000009jn02QAA.jpgThis test2 was added half an hour ago
note:
I found that ,the standby LC must be restarted before the vs can be discovered by active LC.😂
1 REPLY 1
Samir
MVP
MVP
Not observed such issues in LC. Try to create vs again and see the results. If again same issue then check with TAC.
I am suspecting issue with LC settings.​
