Technical Forum
F5 Automatic ISP failover Configuration
EvanRacii
Altostratus
Altostratus
Hi ,
We are using f5 as NAT device. We have 2 ISPs connected to F5.
We are now configured with iRule for automatic failover between two ISPs.
when CLIENT_ACCEPTED {
   if {
    [class match [IP::local_addr] equals "192.168.10.10"]||
    [class match [IP::local_addr] equals "192.168.10.20"]
   pool " ISP_pool_Telstra "
    elseif {
    [class match [IP::local_addr] equals "192.168.10.30"]
   pool "ISP_pool_NTT"
else {
snat automap
What I want to know is , can we configure automatic ISP failover without using iRule ? If yes can help me how to configure ?
Thank you
2 ACCEPTED SOLUTIONS
Paulius
MVP
MVP
@EvanRacii Do your ISP connection have to be used in an active/standby configuration? If not I would just configure ECMP and allow both links to be used at all times. Aside from that you might be able to use the following article to assist you in your ISP failover.
https://techdocs.f5.com/en-us/bigip-15-0-0/big-ip-local-traffic-manager-implementations/configuring-...
Hi @EvanRacii ,
You mean by word automatic failover that you need to automatically switch between ISPs ,
You can replace your irule by local traffic policy it more easier than irules and good for performance.
So search on f5 articles about ( overview on LTM politics)
But if you need to use Active / standby scenario on pools or ( isp pools ) , I mean you want an ISP carries the whole of your traffic but if anything impacted this ISP link you would failover to the second ISP link to carry the whole traffic .... if you need this scenario : I recommend to compine both of isps to be under the same pool and configure what we say in F5 ( priority group activation) it's much effective if you want to make one or more pool members active while the other or others standby.
Just search on F5 articles about ( overview F5 priority group activation or PGA.
If I haven't given you some insights , please explain to me more about your design and what you're trying to achieve.
_______________________
Regards
Mohamed Kansoh
6 REPLIES 6
Paulius
MVP
MVP
Thanks @Paulius.
@423970 - I've marked the answer as a solution. If you disagree, or think there are others in this thread that are also part of the solution you may unselect or mark more answers as part of the solution.
Doing so helps others (on Google and here) find solutions more quickly.
Thanks for being a part of our community.
Lief
EvanRacii
Altostratus
Altostratus
Thank you but I want to know if is it possible to configure Active/Standby ISP  failover scenario withour iRule.
It is not possible without above  iRule?
@EvanRacii Based on the article above it seems like it should be.
Hi @EvanRacii ,
Regards
Mohamed Kansoh
Hi Mohamed
Thank you so much . Let me try group activation or PGA and get back to you
