Bugs17's avatar
Bugs17
Jun 17, 2022
F5 ASM - Stagged blocking settings is not send to remote log
Hi All,
refer to support article https://support.f5.com/csp/article/K15215363 that said stagged attack signature will not send to remote log, but i have some another stagged policy settings is file type, which while i was export from the remote log the url value are blank, but the actual event in f5 are there. my assumption the stagged event log not send to remote log. is that also will not send to remote log?
*that attack signature is enforced
