18-May-2020 13:20
Hi, I tried GET request and received a response 404
https://mgmtip//mgmt/shared/appsvcs/declare?show=full
"code": 404,
"message": "unable to retrieve declaration"
POST https://mgmtip/mgmt/shared/appsvcs/declare received error code 500
"class": "AS3",
"action": "deploy",
"persist": true,
"declaration": {
"class": "ADC",
"schemaVersion": "3.19.0",
"id": "urn:uuid:33045210-3ab8-4636-9b2a-c98d22ab915d",
"label": "Sample 1",
"remark": "Simple HTTP Service with Round-Robin Load Balancing",
"Sample_01": {
"class": "Tenant",
"A1": {
"class": "Application",
"template": "http",
"serviceMain": {
"class": "Service_HTTP",
"virtualAddresses": [
"10.0.1.10"
"pool": "web_pool"
"web_pool": {
"class": "Pool",
"monitors": [
"http"
"members": [
"servicePort": 80,
"serverAddresses": [
"192.0.1.10",
"192.0.1.11"
"code": 500,
"message": "GET http://admin:XXXXXX@localhost:8100/mgmt/tm/sys/provision query target BIG-IP provisioning response=401 body={\"code\":401,\"message\":\"Authorization failed: user=https://localhost/mgmt/shared/authz/users/rajah resource=/mgmt/tm/sys/provision verb=GET uri:http://localhost:8100/mgmt/tm/sys/provision referrer:/127.0.0.1:60320 sender:/127.0.0.1:60320\",\"referer\":\"/127.0.0.1:60320\",\"restOperationId\":1846768,\"errorStack\":[\"java.lang.SecurityException: Authorization failed: user=https://localhost/mgmt/shared/authz/users/rajah resource=/mgmt/tm/sys/provision verb=GET uri:http://localhost:8100/mgmt/tm/sys/provision referrer:/127.0.0.1:60320 sender:/127.0.0.1:60320\",\"at com.f5.rest.workers.EvaluatePermissions.failPermissionValidation(EvaluatePermissions.java:236)\",\"at com.f5.rest.workers.EvaluatePermissions.completeEvaluatePermission(EvaluatePermissions.java:198)\",\"at com.f5.rest.workers.EvaluatePermissions.evaluatePermission(EvaluatePermissions.java:78)\",\"at com.f5.rest.workers.ForwarderPassThroughWorker.onForward(ForwarderPassThroughWorker.java:227)\",\"at com.f5.rest.workers.ForwarderPassThroughWorker.onGet(ForwarderPassThroughWorker.java:492)\",\"at com.f5.rest.common.RestWorker.callDerivedRestMethod(RestWorker.java:1113)\",\"at com.f5.rest.common.RestWorker.callRestMethodHandler(RestWorker.java:1034)\",\"at com.f5.rest.common.RestServer.processQueuedRequests(RestServer.java:1355)\",\"at com.f5.rest.common.RestServer.access$000(RestServer.java:45)\",\"at com.f5.rest.common.RestServer$1.run(RestServer.java:316)\",\"at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:473)\",\"at java.util.concurrent.FutureTask.run(FutureTask.java:262)\",\"at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:178)\",\"at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:292)\",\"at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1152)\",\"at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:622)\",\"at java.lang.Thread.run(Thread.java:748)\\n\"],\"kind\":\":resterrorresponse\"}"
18-May-2020 20:55
Re: 500 response to POST.
The error message says "Authorization failed". The user "rajah" may not have sufficient privilege. Try the "admin" user.
19-May-2020 05:49
Yeah.. shifting the ownership could help you out bp credit card
