Technical Forum
F5 as a Reverse Proxy
rem58
Please provide data on a reverse proxy set-up in which there will be hosting of a number of properties on subdomain. I'll use https://beta.test.alpha com/ as an example which would include a full programmatic microsite, paid media landing pages, a downloadable brochure etc that using this set-up will render on this subdirectory https://www.northeastern.edu/masters-exercise-science-online/
2 REPLIES 2
rem58
1) Is the first step to create a Rewrite type of profile ?
Hi @rem58 ,
Kindly provide one example of your requirement which will give clarity on redirection and/or rewrite required for your URL. Once there's clarity, it will be easier to provide the desired solution. Ty!
