Poseidon1974's avatar
Poseidon1974
Oct 10, 2023
F5 APM-Kerberos -decrypt ticket
Hi ,
I am newbie on  F5 APM, I use Kerberos authentication via keytab, and I have this error message in the  SIEM logs, when user try to connect, also, the user sees a pop-up displayed to authenticate, normally, it should be transparent for the user who is already in the domain
"LOCAL kvno 24 enctype aes256-cts found in keytab but cannot decrypt ticket"
Any help ?
Thanks ,
      • Leslie_Hubertus's avatar
        Leslie_Hubertus
        Ret. Employee
        I've just sent your thread to some colleagues to try to get you the answer you need.
    • Poseidon1974's avatar
      Poseidon1974
      Hi
      Thanks for this reply , we use same account ( AD) for both SPN, for one URL it's OK with AES , but NOK for seconde URL, we haven't any issue with RC4  before
      regards,
      Poseidon1974
      Hi ,
      As explained, I use a keytab file for two spns, only 1 SPN works with AES (without pop-up), however the other SPN does not (the user sees a pop-up displayed) to put his credentials n us 'have no problem with RC4 encryption.
  • Not sure if I can help
    https://support.f5.com/csp/article/K24065228
    Verifying the Kerberos encryption configuration
    The encrypted type in the keytab file must support the encryption used to encrypt the Kerberos service ticket on the client system.
    To view the supported encryption types in the keytab file using the BIG-IP Configuration utility, refer to Verifying the service account name configuration on the KDC and BIG-IP APM procedure in this article.
    To display the encryption used to encrypt the Kerberos service ticket, use the klist command described in the Verifying the Kerberos tickets on the client device with the klist command procedure in this article.
    For more information on configuring Kerberos encryption on Windows, refer to Windows Configurations for Kerberos Supported Encryption Type.
    Note: This link take you to resources outside of AskF5, and it is possible that the information may be removed without our knowledge.
    F5 recommends using the AES 256 bit encryption type. To configure this, you need to enable the This account supports the Kerberos AES 256 bit encryption option on the Account tab in the AD Properties and also when generating the keytab file with the ktpass command.
      Poseidon1974
      Thank you for this feedback (I already knew this link), however, all the steps explanied on your link complete correctly, nevertheless, the generated keytab file only works for a single SPN, and not for the other (the user has a authentication pop-up), following that, I did a rollback to RC4,
