Thomson_Thomas's avatar
Feb 12, 2020
F5 APM and Remote Desktop Gateway
I'm having a weird issue with RDG and APM currently single sign on works internally and externally however when we try to launch any app externally it is saying unable to connect to the remote desktop gateway internally this works perfectly. Even weirder when I just load balance the RDG servers without APM everything works fine externally/internally which makes me think there is no firewall issue. Right now we have a VIP with APM and SSO is configured as below:
NameRDS
Partition / PathCommon
SSO MethodForms
Credentials Source
Username Source session.sso.token.last.username
Password Source session.sso.token.last.password
SSO Method Configuration
Start URI /RDWeb/Pages/en-US/login.aspx
Pass Through Enable
Form Method                  POST
Form Action
Form Parameter For User Name DomainUserName
Form Parameter For Password UserPass
Hidden Form Parameters/ValuesSuccessful Logon Detection Match Type
                          None
                          By Resulting Redirect URL
                          By Presence Of Specific String In Cookie
Successful Logon Detection Match Value
/RDWeb/Pages/en-US/default.aspx
  • Were you ever able to find the answer to your issue? I imagine you saw a new session appear with each "click" of the RDS resource when using the external context. When you increased logging, did you see the SSO failures?
  • our problem was we needed an RDS server facing the internet to get this to work, this wasnt approved so we went forward with 2FA through AWS.
