Technical Forum
Custom Alert Banner
F5 APM (AD+MFA) policy configuation
Preet_pk
Altostratus
Altostratus
Hi All,
Please share APM policy template for F5 APM - AD + MFA(SSO)
3 REPLIES 3
AD APM integration is documented on clouddocs, should be a simple google search.
But what sort of MFA are you intending to use? - radius or cloud based?
There should also be info online for this also.
Hi MVP,
It is radius based MFA.
ok try this for AD
https://techdocs.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-config-11-4-0/apm_config_un...
And this for Radius
https://techdocs.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-authentication-single-sign-...
https://my.f5.com/manage/s/article/K41837805
I have it setup where i do AD first, then on the success branch i then do a radius lookup passing in the same credientials as the AD lookup. But my AD is linked to the radius 2FA, so they both use the same usernames.
