28-Sep-2023 05:35
F5 ADC - url rewrite redirect with parsing
Hello,
I would like to rewrite/redirect a url with parsing a part of old url into the new one
Vocabulary : The Siret number is used to identify geographical location your company and each establishment that makes it up.
Exemple 1 :
From
https://mywebsite.com/oldpath/some-text-with-hypen-siretnumber-uniqueid
To
https://mywebsite.com/newpath/subpath/uniqueid
Exemple 2 :
From
https://mywebsite.com/oldpath/some-text-with-more-hypen-siretnumber-uniqueid
To
So far I tried regex to parse the digits after the last hyphen with no success, I surely miss something, or doing something wrong, here what I put in F5 ADC :
if {[string tolower [HTTP::uri]] starts_with "/oldpath/"}{
scan [URI::basename [HTTP::uri]] {%[\-([^-][0-9]*)$]%d} num
HTTP::redirect "https://[HTTP::host]/newpath/subpath/${num}"
Thank you for any help.
Have a nice day.
Solved! Go to Solution.
28-Sep-2023 07:51
Not tested:
# Capture the URI from the HTTP request
set uri [HTTP::uri]
# Define the pattern to extract "uniqueid" using Regular Expression
# The pattern now captures only numerical characters after the last hypen ("-")
set pattern {.*-(\d+)$}
# Apply the regular expression to capture "uniqueid"
if {[regexp $pattern $uri ignore uniqueid]} {
# Create the new URI by appending the captured "uniqueid"
set new_uri "/newpath/subpath/$uniqueid"
# Perform HTTP redirect to the new URI
HTTP::redirect "https://mywebsite.com$new_uri"
28-Sep-2023 07:41
Can you give some examples of what the strings/numbers look like?
28-Sep-2023 07:54
Here an example : /First_name-Family_name-jobètype-41383279100011-1
And I have to keep the last number in this example 1
28-Sep-2023 07:43
@OMA67 Will the uniqueid always be at the end of the path, is it always the same length, and is it always certain characters?
28-Sep-2023 07:57
Yes uniqueid wich is only digits and it is an incrementation number from 1 to infinite, it is not always the same lenght
28-Sep-2023 07:58
uniqueid always at the end
28-Sep-2023 07:51
Not tested:
set uri [HTTP::uri]
28-Sep-2023 07:57
Thanks, I will try
29-Sep-2023 01:22
Thank you very much ! it works like a charm ! 😀👍
29-Sep-2023 02:08
Good to hear - just love to help out 🙂
