Technical Forum
F5 101 - Practice exams
Ronenb
Cirrus
Cirrus
Hello
Pleae advise if ,https://portal-v5.examstudio.com/Default.aspx?id=20882, exam studio still active.
I cann't rech it with me email nigther my accees code.
Ronen
1 ACCEPTED SOLUTION
https://portal-v5.examstudio.com/?id=20882
is working fine for me now, using my F5000.... login and password used on the certmetrics.com website.
6 REPLIES 6
Lidev
MVP
MVP
Hi Ronenb, same result with my credentials maybe portal exam-studio is under maintenance.
Does some one knows till and if it will be back?
Yes, me too !
Ed_Martens
Cirrus
Cirrus
For me it is also not working,
Did password resets no luck.
I do have multiple account all the same issues.
Also tried the certmetrics account.
Any one a idea???
Reach out to the F5 certification team would be best.
