Technical Forum
Exporting list of Virtual Servers showing their respective pools, persistence profiles, virtual IPs and ports.
Tofunmi
MVP
MVP
I am trying to prepare an as-built for a project I just concluded with a customer. The customer are requested a list that would consist of the following;
1 REPLY 1
Hello Tufonmi.
You can use the Python SDK to export this info. Try this code as template.
https://community.f5.com/t5/crowdsrc/displaying-vs-config-using-sdk/ta-p/280717
Regards,
Dario.
