Technical Forum
Custom Alert Banner
Export device backups from BIG-IQ to an external FTP
Mike757
MVP
MVP
I'd like to know if it is possible to export the managed devices' UCS files from BIG-IQ to an external FTP server. Preferably something that could be scheduled right after it gets the UCS from the devices.
I'm quite sorry if this has been answered before, but I couldn't find anything of the sort. And BIG-IQ's Knowledge Center has all sort of fancy and advanced implementation guides but not a basic user guide...
Thanks,
Mike
1 ACCEPTED SOLUTION
AlexBCT
MVP
MVP
Hi Mike,
Does it have to be ftp, or can sftp work? When you create an UCS backup schedule on the BigIQ, there is an option at the bottom called "Archive". Select that one and it should show you the configuration for sending it straight across to a backup server using SCF or SFTP.
Hope this helps.
3 REPLIES 3
AlexBCT
MVP
MVP
Hi Mike,
Hope this helps.
Mike757
MVP
MVP
Hi Alex,
Maybe SFTP will do. I'll try to check it out today or tomorrow.
Mike
Mike757
MVP
MVP
Indeed! I hadn't noticed that Archive button 🙂 And the customer just confirmed me that the server does support SFTP, so we're good.
Thanks!
Mike
