Technical Forum
Export cert and key from Big-IQ
Bryan_T_
MVP
MVP
Is there a way to export a certificate and private-key from Big-IQ?
Thanks,
2 REPLIES 2
Samir
MVP
MVP
Go through below link. It will give some clue.
​https://devcentral.f5.com/s/articles/automate-import-of-ssl-certificate-key-crl-from-big-ip-to-big-iq-31899
The information at the thread seems to be about importing to BigIQ
How do you export the key/cert from BigIQ?
