Frank_30530
Altocumulus
May 15, 2008HTTP_REQUEST not triggered in HTTPS virtual server?
Hello,
I have setup a simple HTTPS offloading virtual server. We use
clientside certificates. We also use an iRule, because we use
specific parts from the client certificate to perform special
tasks (not relevant to this question).
Using a webbrowser the iRule works. However, it's an application
that must use this VS/iRule. The application does not work properly.
The problem is that I can see a correct SSL handshake and client
certificate being passed to the LTM.
I can also see the application sending an encrypted HTTP request
packet (with wireshark I see TLSv1 application data (application
data protocol: HTTP).
This packet is being ACKed by the LTM at the TCP level
(only a TCP ACK, no data is being transferred from the LTM to the
client application). However, the HTTP_REQUEST event is not
triggered in the iRule and the (SSL/TCP) communication seems to
get stuck.
This is the iRule:
when CLIENTSSL_CLIENTCERT {
set cert [SSL::cert 0]
session add ssl [SSL::sessionid] $cert 36000
HTTP::release
set client_cert [session lookup ssl [SSL::sessionid]]
DEBUG
set cert_data [X509::whole $client_cert]
log "X509 client cert: $cert_data"
DEBUG ENDS
other code not relevant to this question
My questions are:
1) what can be the reason the HTTP_REQUEST is not triggered?
The only thing I can think of is that the HTTP request is
not complete or the application is not sending a valid
HTTP request.
2) Because of 1) I would really like to be able to look into
the unencrypted data being send from the client to the LTM.
Is there any way I can use debugging in the iRule to have
access to the unencrypted raw data send from the client
application to the LTM? (ssldump is not an option).
HTTP::collect will not work as HTTP_REQUEST is not triggered.
TCP::collect probably won't work because I probably get the
encrypted data (which I can also see using tcpdump on the
interface).
Any help/hints are very much appreciated.
-Frank
