Technical Forum
Custom Alert Banner
Expired ssl warning
THE_BLUE
is there any irule to disabled the ssl warning from client side? i mean if the certificate is expired then remove the warning and open the website.
1 ACCEPTED SOLUTION
boneyard
MVP
MVP
No, it is the client (browser) which looks at the certificate and shows a warning if that option isn't disabled (which is almost not possible anymore).
If the server could influence that, the whole TLS/SSL trust system would be broken.
So just update the certificate, which is a good thing to do anyway.
1 REPLY 1
boneyard
MVP
MVP
