Technical Forum
ERP with waf
THE_BLUE
Cirrus
Cirrus
is it possible to integrate ERP System with F5 ?
and is it recommend to integrate it ?
all Functionality of ERP that will work if integrate with WAF?
4 REPLIES 4
Have you seen this:
https://www.f5.com/services/resources/deployment-guides/sap-netweaver-erp-central-component-big-ip-v114-lt
Does this cover all types of ERP ? cuz i need it for oracle not SAP
i could not find the iApp template in WAF.
Have googled to see if F5 has made iApp template for the needed by you ERP system?
If you don't see any contact F5 or Oracle as they should make one if there is customer need.
I found this but it is old and I don't know your oracle ERP name:
https://www.f5.com/services/resources/deployment-guides/oracle-e-business-suite-12-big-ip-v114-ltm-a...
https://partner-finder.oracle.com/catalog/scr/Solution/SCSP-SBLONLCJ.html#solution-resources
Dear Nikoolayy1,
Many thanks i will check them now.
