Sort By
- ramesh_01_13576NimbostratusAnd is there any license required?
- Kevin_StewartEmployee
Best I can tell, the Cisco CSS products are rated by aggregate throughput (6 Gpbs for the 11501) . If that's the only comparative factor, then the F5 6900 supports 6 Gbps. The new 2000 series supports 5 Gbps, and the new 4000 series supports 10 Gbps.
As for licensing, please refer to the following site for information on what you can do with the platform.
http://www.f5.com/products/big-ip/
