Technical Forum
Custom Alert Banner
Enhanced SSL stats in iControlREST
altonlindsey
Are these stats in iControlREST? https://my.f5.com/manage/s/article/K41057430
I am able to grab stats from https://bigip/mgmt/tm/ltm/virtual/test_vs/profiles/test_clientssl/stats but I would like to capture SSL specific fields the article references.
I would like to avoid cli/bash since the rest of my work uses rest.
Alton
1 ACCEPTED SOLUTION
altonlindsey
I found it! under:
/ltm/profile/client-ssl/[profile name]/stats'
1 REPLY 1
altonlindsey
I found it! under:
