Thiyagu_343098's avatar
Thiyagu_343098
Feb 10, 2019
Effective way to compare the cofiguration of VIP on two LTM devices
Hello All, I'm working on the task to compare the configuration of two VIP IPs on two difference LTM devices.
These LTM devices are managed by BIG IQ..
Could you please help me to know whether is it possible to compare the cofiguration of two VIP on two different LTM using BIG IQ?
Regards, Thiyagu
  • Hi Thiyagu,
    You should be able to do it with the snapshots I believe. I personally haven't used it, but have known from the articles I read.
    Also the same can be done through Ihealth portal too.
    But as this is a simple comparison, I personally depend on the text editor like notepad++ to simply compare it.
    May I know what final task are you planning to achieve.
