Technical Forum
Custom Alert Banner
Edge VPN client for MAC
a_basharat_2591
I am not very strong with MAC device. When downloading the Edge VPN client for MACs from the F5, it comes as a zip file containing two files: config_tmp.f5c & mac_edgesvpn.pkg
I understand that "mac_edgesvpn.pkg" is the file that a MAC user needs to open and install on ther desktop.
My question is: What is the purpose of "config_tmp.f5c" and is that file needed for the installation, when and where then?
1 REPLY 1
a_basharat
Any idea of what the config_tmp.f5c is for?
