VFB's avatar
VFB
Icon for Cirrus rankCirrus
Sep 29, 2020
DUO SSO Credential mapping error
I've been trying to work around an issue where SSO isn't passing the user credentials over to storefront logon page. It populates the username, and I presume the password, but I receive invalid username/password error. I then click in the password field to apply the save password and it logs me in.
  • try to log the variables and see if they contain what you expect.
    if there are weird character you might give it a try with a very basic password for testing
    nicest would be able to snif the traffic, but that will cost some effort and decrypting it probably.
