Technical Forum
Custom Alert Banner
Domain redirect using policy.
DG
0691T00000Cr14wQAB.pngHello,
I have a server that has a domain name and the corresponding SSL redirect. I was asked to add a second domain name to the same server and perform a redirect to the original name when the http request comes in before the SSL redirect.
I have created a policy, unfortunately the redirect gets executed before my policy and I end up with un-trusted certificate.
Any suggestion would be greatly appreciated.
Thank you,
dg.
3 REPLIES 3
Sajid
try this
0691T00000Cr1DFQAZ.pngin the redirect to location, "[HTTP::uri]" to keep URI.
DG
Actually your suggestion was one of the first I did try. It is still doing the SSL iRule redirect first and then redirecting the URL. I am just wondering if a better solution would be to have a separate Virtual Server only for port80 and set the redirect Policy there. It is not that elegant but it should do it. On another side, I believe that Policies are evaluated before iRules, am I correct?
0691T00000Dy8VnQAJ.pngThank you,
dg
Sajid
this may help you
Verifying Local Traffic Policy and iRule Precedence
https://devcentral.f5.com/s/articles/verifying-local-traffic-policy-and-irule-precedence-31680
K16590: The BIG-IP system now processes the local traffic policy before evaluating an iRule
https://support.f5.com/csp/article/K16590
